do t bar upper control arms fit on arm rangers???
Heavyfire14
imperial valley
do they even have upper a arms? will they fit? i looked on summit and it keeps showing upper control arms for a 2002 ranger xlt with T bar suspension??? will they fit my truck? i feel stupid but, i need help! thank you.
Do you have coil springs in the front?
The answer to that will not be the same as the answer to your question.
Your truck has upper arms, but I think they are different from the T-bar ones.
do you have to replace the whole upper arm to replace the ball joint? (i know your gonna say yes but, i just have to ask) do you know the part number by any chance?
i tried to rep you but it wont let me... i musta just repped you last week i guess.
they appear similar, but definately are not interchangeable.
T bar arms are about 1/2" wider, that is they push the top of the steering knuckle out 1/2" farther. The stud on the ball joint is larger and won't fit into a coil spring type steering knuckle.
most coil spring type upper arms have a built in ball joint, the whole piece gets replaced.
Perry
u could try to fit 99 a arms on your truck(coil sprung of course) so u get replacable ball joints.
i have to give that ide a atry for when the 03 needs ball joint replacing.
also ill try to remove the ball joint and see if i can make a 99 one work in there.
im actually gonna replace it with a moog arm(s) because they allow you to replace the ball joint only, their 92 bux each on summit
