This has been getting worse. At first I thought it was the cold doing it, but I think its getting worse.
I'll turn the ignition switch to start, and the engine crancks a couple revolutions, and then stops, but the starter continues to wiiiiirrrrrrr.
These have the starter solenoid separate, located on the fender well, or someplace right, so if the starter is getting power, then its the pinion gear in the starter not working right, and need to replace the starter?!?
Whats the procedure for replacing the starter on an '89 Ranger with the 2.3L, and A4LD tranny?
