88mudder
- Aug 26, 2007
- Age
- 36
- waterford michigan
Mass confusion here and hope i can get some help.
I am swapping in a EB44 into my Ranger. EB bottom coil spring plates, 5.5 EB coils and 79 bronco upper coil buckets. Everytime i go to try to mount the coils into the vehicle they are always off by 90 degrees bottoms relation to the tops if that makes sense. I can mount them into the bottom plates and then when it comes to ataching them to the coil buckets they are off by 90 degrees and dont sit correctly and vis versa.
Do i need 78-79 bottom plates? Do i need EB coil buckets? I really want to use the 79 bronco buckets cuz if i use EB buckets im going to have 2 much lift since they sit lower..please help!
