DJM drop kit
Its a 4x4? Going by your info under your avatar. You won't be able to get too much out of it. Why not lift it a few inches?
James
I dropped my '89 front end 3"--had to lengthen (screw out) the tie rod ends to get the toe-in set again--it was out a lot after the drop--I used the string tricks in the tech library to get the toe-in back where it should be...
