DIY clutch: How do I...
Touring23
Prevent the flywheel from turning while loosening/torquing the PP and FW bolts?
Seems like there should be a tool available.
What's the purpose of the aluminum gasket-plate thingy?
It's a '93, 2WD, 2300.
OK thanks.
Got 'em loose by clamping the flywheel with a large vise-grip, but it was a struggle. For next time, I'm going to drill a piece of flat bar stock to slip over two of the FW dowel pins.
For installation, it occured to me to use the front crank bolt and a breaker bar to hold the crankshaft. It's a 7/8" socket for the 2300, if anyone cares.
What's the purpose of the aluminum plate between the tranny and the engine?
Keeps road grim out of places it shouldn't be.
a simple trick is to put a tranny bolt back in and use a pry bar between the ring teeth and the bolt it takes a second set of hands but works pretty well.
In really bad situations use one of the tranny bolts and a clutch bolt with a length of chain between them just be carefull use junk bolts so you don't dammage the threads of the bolts you are going to use for the install.
Good ideas, Ish :icon_thumby: That never occured to me.
Also found a tidbit while searching the archive: use a pair of 3/8" all-rod in the lower mounting holes to guide the tranny during installation. I don't remember whom to credit.
Thx jsp...
