carcraft302
I posted on my old thread that my new MSD distributor wouldn't seat, but the old distributor (minus gear) seemed to seat OK. The MSD sat about 0.124 inches to high. Well I got it fixed and wanted to share a little of my joy. Heres how I did it. I took a dowl about the same size as the distributor shaft and measured the hight of the oil pump rod by marking it against the opening in the block for the distributor. I got some assembly lube and put a tiny blob on the end of the MSD shaft and put the distributor in and rotated the shaft. The blob wasn't squished. Next I took a tiny blob of grease on the bottom of the gear, rotated the distributor and no squish. Went to the parts store and measured the depth of the rod hole in the old distributor and the MSD. The MSD was deeper. I put the MSD in and was going to use feeler guages to measure the exact distance. I noticed the distributor could be pushed down but "sprang" back to the original position.
I put the old distributor back in and noticed it was a little proud to. I tapped on the old distibutor shaft with a hammer and it "gave". I taped until it seemed "solid". The MSD now seats fine and the pump rod didn't move.
I think the pump rod retainer was out of position .
Thank God I didn't have to pull the engine again..the joys oh the joys
