Trfsrfr
- May 27, 2013
So I have a new Cam Position Sensor, or Pick-up Coil, or Distributor Stator, or Hall Effect, or whatever it is for my 1993 3.0 Ranger with distributor.
Im finding out that these are not the most common setups and there is not a lot of info on them.
I thought that replacing the sensor would be just a matter of removing the cap and rotor, then removing the two bolts that hold the Rotary Vane in place to get to the sensor but thats not working.
Do I need to remove the distributor to replace this sensor, or is there a setscrew or something I am missing?
Thanks-
Thanks-
