disciplerocks's B2 build thread
:thefinger: your clearance issues
Damn Dustin, You've been after it! Looking good!
Thanks. Had them mounted today, then pulled in the driveway and put her on jackstands. Replacing front axle u-joints, wheel bearings, and doing a c-clip eliminator.
Also want to note that it still fits in the garage, which was something I was worried about.
Don't just follow the instructions in the thread about where to lay the bead to position the spring. Test fit. SVT & I just did it per. SVT's needed to be out a little more. I've not had a problem with mine. And I did have 'er twisted up pretty good at TB & Smokey Ridge after I installed it.
Yeah, and now I need a new passenger inner axle shaft...mine is almost completely stripped out...
SVT
SVT
You got a whole d%$# 60, some weld in bungs with johnnie joints, get after it already! Or just slap that 8 lug 44 in you've had laying around since before I met ya! It's more than enough for that little 5.0 ya got.
I got a damn black midget taking up the time and tools right now....I can only work on one project at a time!! :thefinger:
SVT
that's sexy... i like those tires!
Hey Dustin, how's clearance at full lock and full bump?
