djurs
The TPS reads out 1.01 volts at idle and when revved (not sure how high, maybe 2000 RPM), it read 1.25 volts. I'm not sure how to test the IAC motor, I hear resistance testing is spotty, and I don't even know the values to look for. I touched an ohm meter to both prongs on the motor and got a 0.00 value, but I can't remember what scale I was using.
I cleaned the throttle body with throttle body and carb cleaner. I noticed of the two ports that go to the valve covers one had strong vacuum and the other none at all, I don't know the significance of this, but I'm curious if anyone knows the purpose of those ports.
I read codes out, both KOEO And KOER, both returned code 11 - System Ok.
I sprayed that throttle body cleaner on the vacuum lines in the engine compartment, but I think it was a waste since the engine did nothing but choke on the stuff while I was cleaning the throttle body, guess they do that to prevent engine damage due to too much highly flammable materials entering the engine. I hear brake cleaner works good for finding vacuum leaks... I haven't been able to find any any other way.
Any suggestions or ideas are helpful. I'm almost to the point of taking it to a shop, but I'm just worried no one there can find this problem without throwing parts at this thing.
