odews
- May 28, 2008
Hey everyone... First off this is my first post since September of 2000. Secondly I now have a 94 ranger 2.3L (although it is a 94 the engine bay is identical to my neighbors 95 yet different from my friends 94??)
Here is my issue... (I am not getting any error codes)
When it is cold outside, my Ranger takes two to three starting attempts to get running.(sometimes five or six) The motor starts but dies immediately. I can hear the fuel pump pressurize and the pump and fuel filter were replaced 8k miles ago. Some other symptoms I have is that I lack power when taking off from first gear and when shifting into second. The truck also bucks a bit at low RPM's. I usually rev the engine a bit to keep RPM's up which helps in bypassing the problem.
My first thought is that I may have a vacuum leak in a line to the fuel pump or somewhere else. I believe that it is also possible that my fuel pump went bad.(I hope not)
Any thoughts/suggestions?
I would rather try a few small things before pulling the bed off and testing the fuel pump.
Thanks in advance.
Thanks in advance.
