Differnt intske for 3.0
matt072189
OK i have a 1996 3.0 i would like to put a intake with a throttle bodie on it what might fit ??
id start with an '02+ composite plenum with a removable throttle body (yours should be integral). after that, the bbk 1548 tb is 56mm (stock is 50mm) and bolts on, but requires re-using the original throttle shaft. a 60mm escape tb can also be used, but requires gap filling with jb weld and other minor modifications.
if you want mods on the cheap and easy, you can half-shaft your current tb.
I will also need the lower intake? should everthing hook up right?
you only need the upper intake...but if i recall correctly, you need to drill the holes out (something like 6mm to 8mm) and re-use your original studs and bolts.
