ricardo93
What kind of truck can I take the spider gears out for a tighter ratio? And how can I make it a locking differential on an extremely low budget?
I wish I knew what you were talking about.What kind of truck can I take the spider gears out for a tighter ratio?
The guys above have said how to make a locker, however, if you want a cheap limited slip you can add an extra side gear shim/s to create a cheap limited slip. It won't last too long and there is added stress on the side gears and spiders so there is increased chance of the rear grenading. That said, I've done the same to a 9" and a d-28. The 9" has about 20,000 klicks, the d-28 a couple of thousand.And how can I make it a locking differential on an extremely low budget?
I do want to change the ratios... and how simple is it to do a lincoln locker ?
The 7.5 axle is not a strong axle. I shredded spider gears twice on 30" tires while hunting. Not even trying to play offroad.
