Differences between 95 3.0 and a 2003 3.0
yzrider67
Monroe, WA
So the motor in my 95 is on it's last legs and I managed to find a low mileage motor from an 03 to replace it. My question is will this be pretty much a direct drop in or will there be some parts that need to be swapped over from old to the new?
I plan on replacing the clutch, water pump and pulley's anything else I should consider?
I won't have the new one here for about a week or two so I'd like gather up anything I need while I wait. Yes I did search.
Thanks!
Steve
I'm pretty sure the intake can be adapted to work, only difference I know of is the heads and the block casting is different, I think there's a write up on the composite intake swap
