- Aug 6, 2007
- Age
- 60
- Hersey, Mi
The M5OD R-1 will fit. You need the Trans, flywheel, clutch, clutch line,starter and inspection plate. You can pull the pilot bearing out of the crank because you won't need it. The 4.0 uses the pilot bearing in the flywheel. The crossmember will need to be moved to a new location, The holes won't be there so you will have to drill. The shifter will be in a slightly different location so you may have to modify the plate in the floor. The 4.0 uses a larger clutch so you will be upgrading there as well. The 4.0 starter is a permanent magnet style which uses less amperage to run so that is also an upgrade of sorts. The starter needs a small modification of wiring to work.
Oh, don't forget, You will also need the bellhousing bolts.
