bleedingblue
- Apr 30, 2010
- Automatic
Difference between Ranger Edge Spindles and Non Edge Ranger Spindles
I have a 99 Ranger with coil springs up front. I know the difference between mine and a Ranger Edge is the Edge uses torsion bars up front. What' is the difference between the spindles on both trucks? I need the center shafts from the spindles to have pressed into my camburg spindles. I found a set of edge spindles used for 20 bucks. Will the edge center shaft interchange with a non edge center shaft?
