Diff swap
88~ranger
Vancouver, Canada
Hey, im hopeing you guys can help me out. Im looking to do a rear end swap in my '88 ranger. Before i can start getting excited ive got an amature question :icon_confused: I need help figureing out what the gear ratio is in my current diffs. ive got the codes from each:
Rear- AS308B 73 75 9F02
Front- 3 73 VE87A V610307 2
im guessing that because my front one says 3 73, then thats the gear ratio?
If you can help me that would be very much appreciated!
Thanks! :icon_cheers:
Yup, you got it right. I'm guessing there was a 3 in front of the 73 in the rear number as well, but it could have been flattened out or scraped away.
http://www.therangerstation.com/tech_library/Axles.html
http://www.therangerstation.com/tech_library/4wd_Front_Axles.html
there is some information about the axle tags for you. The Tech library link above holds t his and all sorts of good stuff about the ranger :)
from your tags, it looks like you have an open carrier 3:73 7.5 axle on the rear (take a close look at that tag again, and I would imagine that it is AS3083 73 75 9F02), and your front looks like it is another open 3:73 Dana 28.
hope this helps.
AJ
Go for the Explorer 8.8 swap. It's a bit higher on the difficulty scale, but 3.73 geared exploders were about as common as corn on a farm.
