- Aug 6, 2007
- Age
- 49
- Berrien Springs, MI
- Manual
- My credo
- If you can't go through it or around it, then go over it.
a 6.2/6.5 will fit in any hole a 350 will. will bolt to any transmission a 350 will. to do a 4bt swap you still need a GM transmission (I know some ford applications are rumored to exist but the GM app is far easier to find) and a 4bt will not make the power a p400 optimizer will....... there is a guy on DTR that is running 303rwhp and 597 rwtq out of his 6.5TD.
for fuel mileage you will be $$$$$ ahead buy doing the 4bt swap or a merc TD or ....... even a TDI swap is possible.
