diesel
das ranger
1993 ford range
im new at this and still trying to make my way around so if you get pissed off owell. i was thinking one day about the benifits of haveing a v8 diesel under the hood but i don't have the money or an engine jack to do so. so i wounder if it is in reach to convert my existing engine into a diesel, and if so what will it take and what is the ups and downs?:icon_confused:
Yeah... probably not gonna happen... GM tried that with the 350 or something... didn;t turn out well at all! You would need a whole new strengthened block, heads, pistons, crank... you would pour probably a good $20 thousand into the ranger engine and about 20 thousand in labor (or labor hours if you did it yourself) by swapping in a diesel v8.
You would gain some gas mileage I assume from it, and after about 10 years of driving atleast 20,000 miles a year it might pay itself off. other then that you couldn't tow much more then a mildly more then stock ranger without upgrading the chassis...
if you want to check out a cool diesel ranger I suggest either BobbyWalter (I think thats his name? with a 6.5L in his ranger) or Dalipont (sp?) who stuck a 6.0L powerstroke and uses it as a drag truck, he got a link in the TOTM catagory.
well then wich would be easer to install and have working, a 4.0l v6, 5 0r 6 something liter deisel, or poor money into the engine i have already? just to let every one know im turning this into a offroad truck in i could use some extra torque but diesel engines could be hard to install.
ok ive got a 2.3l 4-cyl engine with five speed forward manual transmision. i guess im going to put a new engine in it so what engine do i get that will be easy to install and cheap enough. and i prefer if it could hook up to the trans. i already have.
A turbo coupe motor will get you around the 210 hp range more with simple upgrades they would get you the tq and hp you want with the least amount of money.... it depends on wat you want to do mostly... the tc motor is a 2.3 turbo motor that has the most bang for the buck imo... but others on here might say different... and aa plus with the right tune youll get good gas mileage too
why don't you install the ih 2.8 liter turbo diesel, the ranger and range rovers use, in south america and europe?
the motor is made in brazil, by i-h - navstar.
they are averaging 40 mpg.
you would have to upgrade your front springs as the diesel weighs a bunch more than your gas engine.
were do i get one? will it hook up to my transmision? does it involve alot of wires?
the motor is made in brazil by i-h - navstar.
contact a recycler, ie wrecking yard, they may have connections with a parts importer. or contact ih/navstart brazil, through the web page...
another option is to get a vw diesel and using a adaptor mount it to your clutch.
The International 6.9/7.3 is a converted gas motor if you want to look at it that way. They did it the same way as GM did--use the basic design of the gasser, but re-design everything. Neither actually converted a gasoline engine to run on diesel fuel. The International guys got it right. The GM guys got it pretty nearly right, but I think it was GM corporate that made the engine fail--even though they sold over a million of them. In 1978 there was no distribution for diesel fuel for passenger vehicles. The average person was duped into thinking owning a luxury diesel-powered car was the same as a gas car--just fill it up and drive. GM didn't even have a water seperator installed, and with a half-assed fuel distribution, given the fact that diesel and water are similar weights, pumping water into your tank was a common problem. The other problems with the engines (there were 3--a 350 V8, a 260 V8, a 260 V6) were easily correctable, and in the case of the V6, was a good engine. Rushing to production in an effort to get the drop on the other manufacturers caused things to be built before being adequately tested and the problems shaken out.
The 6.2 wasn't really the cure for the Olds-based diesel, it was designed from ground up for trucks. It was in service for 4 years alongside the Olds engine. The Olds-based diesel engine was offered in 1/2-ton 2wd trucks for a couple of years, actually. To GM's credit, they had the balls to build full-size cars with diesel engines, and they built and sold a lot of them--over a million. The one-millionth Cummins-powered Ram rolled off the line last year.
The 6.2/6.5 is a good choice for a Ranger because it is cheap, still in production after 30 years, accepts any GM transmission, weighs a manageable 760#, and responds well to turbocharging. You can install a 150hp $500 6.2 pulled from an Army Humvee off of EBay, and later, when your finances improve...the sky is the limit.
Check out Bobby's installation.
http://www.therangerstation.com/forums/showthread.php?t=35931
Lets be honest, what is your skill level? Swapping to a different motor is not changing your oil. I think the easiest way to gain the power you want is to swap in a 2.3L turbocoupe engine (or any factory 2.3t). Use the factory IHI turbo as they spool up very quick for off-road torque. This will bolt to your current 93's transmission and you can reuse all of the engine accessories. If you cannot do this swap, there is NO WAY you would be able to do a V8 swap or a one-off diesel engine swap. Even if you did stuff a torque hungry diesel into a ranger, you would still have a ranger frame. My 302 at peak torque would fight the stock frame. I ended up boxing the frame up and adding 2" DOM tubing for cross bracing. I can't imagine what is needed for a diesel that weighs over 2 times the weight of a small block. lol
I don't know ..... a GM diesel swap is so simple a geico caveman can do it.
I agree, if you can't handle a swap where the engine bolts in you won't be any better at replacing all the juicy parts of the powertrain.
I have never done a V8 diesel swap, but I would have to think my gas V8 that plugged in the existing ignition system, fuel system and I reused all the accessories was simpler... and it still took some head scratching to do.
