Did I win the electrical lottery?
STX Monk
Wisconsin
I have an odd electrical problem. No high beams, no cruise control, 4x4 switch doesn’t work, the cigarette lighter is dead, and the climate control temp dial is stuck on hot. I don’t know if it matters but the ignition lock is very loose and I can start the truck without the key in. The temp dial, cigarette lighter, and cruise died almost at the same time. High beams where next to go. Just found out last night that the 4x4 switch does not work. I am at a loss. It seems like random things that should not be related to each other.
:icon_confused:
What I have tried:
I have checked all my fuses
Replaced the head light bulbs
Checked all the electrical connections
I did notice last night that my wiper delay is not consistent. Could it be as simple as the turn signal switch having a short and needing to be replaced?
Thank you in advance.
No, I did not. To tell the truth I thought if it started the truck it still worked lol. I will try that.
Thank you
hey give a whirl and good luck man and let it how it goes ..
