if its an older vehicle like mine i recommend rubbing compound, it takes a dull layer off the clear coat, my dull grey trk turned silver again, its worth the money, just a lot of work. basically just go over the painted surfaces (not the plastic or chrome as it will mar them) and w/ a clean rag buff it in by hand, then take a clean rag and wipe it off. id test in an unnoticable small place place first and see the result. somewhere on the quarterpanel or the fuel door is a good spot. if your looking for a streetfighter look (ive considered doing this myself) on extreme dimensions (www.extremedimensions.com) there is a body kit for 90-94 rangers you may want to look into, i didnt see anything else for any other models tho sadly.
For
