Mark_88
- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
So...I have the truck with the 3.0 in my possession...I was going to try to finish off my season before doing the swap and might make it. Problem is, I just found a 2.3 from a 1990 mustang that has less miles than the 3.0 but not sure about its general health and well being.
The choices are:
1) Swap in the 3.0 with 275,000 clicks but runs like a top. This involves a complete swap...fuel lines, dash, steering (to use p/s because it doesn't look like I can delete it) and maybe a drive shaft (the doner truck is a regular cab and mine is ext).
2) Install the complete 2.3 with 193,000 clicks and use my current setup and not have to change the fuel system, drive shaft, or dash.
I can always do both and have a 5.3 if you add the two together...or do the 2.3 first and if it is another blow-by fiasco do the 3.0 in the spring or later this year as needed.
The choices are:
