dllang
- Jul 13, 2008
(and underpowered is saying something for this old slug). I have a 94 ranger XLT 169 K miles on it. The engine is the 4 cyl 2.3L slaved to a 5spd manual tranny. Last winter I replaced the timing belt, plugs (not Bosch), plug wires, and other general tune up items. A couple of months later, the tachometer started to show an odd reading. It would indicate about 1/2 of the RPM that I knew the engine was running (this could occure while driving, so I could see the change). Also, when the tack would act up, the check engine light would come on steady. Other wise, the truck was running fine. This past week, I noted that the tack is completely dead, and the Check engine light is on steady. I also noted that during acceleration, you can feel the acceleration strengthen and weeken as if it cannot decide which set of plugs to use.
Question 1) where does the tack get its signal?
Question 2) Are the tack and the poor running conditions likely linked?
Question 3) Does the Crank position sensor have any thing to do with all of the above? (its the 1st thing that came to mind, but I'm not that familiar with Ford designs)
