Terry
My gas gauge has not worked for at least a few years. I needed to replace the fuel pump in the gas tank. I ordered the whole assembly "sender, pump" from rock auto. I removed the bed and put the new assembly in. Fired up the truck and still no fuel gauge. I'm looking for a "good set" of wiring diagrams. I know that the wire from the sender should go to a resistor and then to the gauge. I disconnected the oil pressure gauge as well a the temp gauge a long time ago
. I am running a set of analog gauges. Does any of the other gauge wiring need to be hooked up for the gas gauge to work?
