Dash Swap?
fabman_52
Corbin Kentucky
1990 & 1987
HI All'
Can anyone tell me, what is the newest year dash that will bolt up to an 89/92 cab? Been told up to 98, just looking to verify. Has anyone done this swap and if so do you have any pix?
Thanks, George.
A Gen 3 into a Gen 2 is not plug and play. The mounts are different, for one, not to mention the electronics are 100% different. Nobody has done it that I've seen around here.
there is one guy on here that is swappin a 4.0 sohc in his gen 1...it can be done...if you are good at fab work
Yes, but you need to qualify your response. It's not as simple as bolting it in, there are a lot of things to consider on the eletrical front. HVAC is completely different (eletronic vs vacuum)- that's a biggie.
I have a 97 ranger dash in an 84 ranger. I can be done but not for the faint at heart.
picture.php
[/IMG]
A little info on the whole project.
The dashes are almost the same width so that was not a problem. I used the heater assembly out of the 97 and all the wiring from the 97. Tilt wheel out of a 99 explorer. I have an air bag too. I was surprised that the firewall in the newer truck was very similar, so making everything fit was not too bad. An automatic truck would even be easier. I used a newer brake & clutch assembly to fit under the dash. I did have to do a little cutting & welding on the upper firewall so the newer dash would fit tight up to the window. It actually looks like it belongs in there. I also used the gen 2 door panels to make it look a little nicer. It gave me delayed wiper control, AC capability, cruise control and a lot better electrical system as I used the entire electrical system off the 97.
Hey, runningman, what did it take to put gen 2 door panels onto your gen 1 doors? I noted that the handles were very different, are they in the same spot? I was looking forward to doing the same swap and was hoping it was as easy as swapping the handles and the panels, is it?
x2 I wanted to know the SAME thing. I bought a 91 parts truck and would love to have that interior in my 88. Will it go in (plug and play)?
I am looking at doing the same. Might get a 95 donor motor and want to swap the 95 dash into my 89. Need to get as much info as I can before I buy it.
The doors panels was actually simple i think i had to drill 3 holes total just take everything from the gen two and once your door is stripped on the gen 1 it fits right on. the holes need to be drilled for the new door handle and then the arm rest plate . The gen 1 door is set up to fit the newer handle slude right into place .
This is runningmans son.
I am about to start my swapping.86 Bronco2 97 5.0 Explorer AWD.REAR axle assy. any info and pictures would be appreciatd
I gota get some measurements on this im gonna be doing this with a 98 mercury mountaineer into my 90 ranger found the merc with a 5.0 for $300 cant wait guess i need motor mounts and to flash the pcm a complete swap should be so simple.
