i finally finished my 94 exploder 4.0 to 90 ranger swap, i took all the wiring from the exploder but the dash. my dash lights wont turn off and the door chime wont go out either even when the keys are out and the main light switch is off
i have both evtm's for both years and make but all the wiring from the 53 pin connector to dash is the same for both years, same color wire and routing to each switch? can the actual switches go bad just from swapping wiring? and yes i took everything but the dash, engine, headlight, transmission,fuel and rabs wiring i even swapped the rabs perportioning valve on the frame rail so i have no idea what any of this has to do with the dash
