Dash board removal
Robert_1967
White Pine, TN
Does any one know where I can get some info with pictures on how to remove the dash board out of a 88 supercab, with out tearing it apart ??
Thank you
Robert
if it is the same as my '83, just pull off the lower trim pieces (pull off the light switch knob first, making sure the lights stay off), and remove the screws under them. then i had to take the speakers out of the top of the dash so it would clear when coming off. then remove the screws under the dash pad. at that point, it should just pull forward and up and off. pad and steel dash were all one piece on mine. good luck.
