Dan's 5.Ohhhh Build thread
She's been on the road for the past 3 days now, problem free, got the exhaust done, alignment done, E-fan, etc, etc, etc...
I will start on making a full write-up for this swap for others who are interested!!!
________
Honda CN250
Good stuff! I am planning to do the same with my '00 2.5. Was your ranger originally a manual?
I didn't read anything about you switching out your'e fuel pump for fuel pressure. Was there any mods that you had to do with the whole gas situation?
Ended up running a 2000 Explorer ECU *returnless*
I used a tuner to remove the PATS from it, but now have issues with the CPS sensor not working due to it being a 2 wire, not a 3 wire or something... I'll get it worked out.
________
KTM 525XC-G
Dan, you talking about the cam sensor or the crank sensor?
Dave
If you really wanna have some fun, buy a set of electric exhaust dumps. The button to activate them is sooooooooooooooo hard NOT to use!! :D:D
Dave
It was the Cam sensor, I am still not 100% sure if it is lined up right, but don't want to shell out the $50 for the mechanical adjustment tool, nor is there a way to line up the 00+ Sensor with a volt meter as it behaves differently than the 96-99 3 wire sensors. Any suggestions?
*Sry I haven't been more active on these boards, I will now since I kinda own 2!!!*
Truck is Factory headers into 2.5 down pipes into 3 inch Y, into a single Flowmaster 40, Dual 2.5 exit on the pass side, no cats... I don't think I need a dump :icon_thumby:
________
starcraft 2 replays
Small update, Fixed my tach, Hosed my ECU With a bad tune it looks like :( Sadness
Updated first post, TIDE THE WAVE OF DRAG RACING 3.0's!!! BUY A V-8!!! :-p
This write up has been one of the most helpful items I've read. The 3.slow aint cuttin' it.
I agree the 3.slow was not cutting it. I dropped in a 5.0 in my 05 and now I have plans to build a 1st Gen on 'roids. :yahoo:
Thread update:
Comp Cam:
Cam
Roller Lifters
Double roller timing chain/gears
Double valve springs
Retainers
ProForm Roller Rockers
Need to install my 8PSI pulley, fix my new exhaust leak, and some other nick-nacks
http://www.youtube.com/watch?v=1Ems7SenzKg
