Dana 44 TTB
rustyballs
Dryden,Ontario
ok,I just add an inch to each I beam, I have an 93 ext cab also have 4 inch drop brackets do i have to move the lower ball joint to, and will the 4 inch kit be to high. The truck is a sas dana 44 norrowed just starting something new. Always like the prerunner style
Sorry, No, the truck is a 93 ext cab 4x4 converted to a dana 44 solid axle front. but I decided to change it back to a TTB and put the dana 44 ttb in it. I already added the extra 1 inch to each beam to get it to bolt up to the original brackets, Iam going to use 4 inch lift brackets to get the front diff away from the frame. I was told and seen people move the lower ball joint, but wasnt sure if would still have to do this also was wondering if the lift brackets would be to much.
If you ditch the drop brackets you will need to extend the lower bj. 4" is plenty, my truck is 4.5 on extended d35s. It cycles enough up travel..
