- Apr 9, 2008
- Age
- 45
- edison nj
- Automatic
what is the pig? i am lost
I would not suggest making a habbit out of driving with out the front pig in,when the pig is out it dont take much to bend the beam then.
As long as you put the pinch bolt back in and tighten it down, you'll be fine. The third member provides very little structural support for the beam.
what is the pig tho seriously, i dont know what it is, its a lil embarrassing
It's a medium sized farm animal. Makes pork, ham, bacon, some sausages, etc.
It's also Rosanne Barr.
But I think the pig you're looking for is a differential assembly, case, and housing (front or rear). Also known as the 3rd member.
I would recommend against running full-circle snap rings on your front joints. I have found that they cause the cap to spin freely and "egg" out the ears of the shafts, ruining them. I ruined a set of shafts in a little over a year with full-circles.
What I'd recommend is to use the stock clips and tack weld them to the ear so they can't pop out. Also, you can put 4 small tack welds on top of the cap to the ear. These two steps will ensure that the cap does not spin, and that you won't spit out a clip. It will also save some time as you won't have to grind down the ears. To get the joint apart you'll have to grind off the tack welds; it's not too hard. I can usually have a welded joint apart in a few minutes.
Actually... the clips don't cause the caps to spin, that's simply because of the torque flexing the yokes, allowing the caps to wiggle around in there.
