redjmp
- Jan 25, 2009
- Automatic
Hi everybody!
I have a 97 ranger 4.0L with a Dana 35 TTB.
As the steering wheel is turned, a progressively louder noise can be heard.
It really sounds like gears that aren't meshing is the best I can describe it.
It is not a grinding or screeching but a rubbing, not so metallic as to sound jangly and not so muted as to sound rubbery but somewhere in between.
At first I thought it was the tread on my new tires but this is not the case.
The tires do make a little noise but it is different than this noise.
There is no noise when driving straight but as soon as I turn the wheel it starts and just gets louder the more I turn.
*But* it only does it while turning 1 direction.
Usually to the right but after driving for a few minutes, it will then change sides and only do it while turning left!
10 minutes later and chances are good that it will be doing it from the right side again and so on.
Never both at the same time.
I have tried to make it change sides by cornering hard left and right while braking and accelerating but no luck, it just does it seemingly at random.
I have replaced all the ball joints, the rotors (with new races), pads and made sure the tie rod ends are fine.
Also checked the ujoints on the axle shafts and they were fine.
I even installed a newer set of auto hubs as I thought they might be the problem but they did not help either.
They work fine otherwise.
I have even removed the cam so that the hubs cant lock and drove in 4wd and the noise is still there...maybe even a little worse.
The wheel bearings were repacked and seemed fine other than minor wear and have no slop and I even turned the wheel nut 1 more notch than normal but the noise is still there.
I don't know what to try next.
I am at my wits end.
Any and all suggestions will be greatly appreciated.
