Dana 35 Spline?
Does anyone know what spline the axle is on a Dana 35? I have a 2006 ranger, just wanna make sure I buy the correct ring & pinion set.
Spline isn't relevant for the ring & pinion gears, but to answer the question, all D35s come factory with 27 spline shafts. What IS relevant though is that your '06 D35 uses standard-cut gears (not the reverse-cut). Be sure that's what you get for it.
Hope that helps.
wow thank you so much I didn't even consider that i was on the verge of ordering reverse cut you saved me a lot of money
