DANA 35 Axle Seal
Ditchbanger
Maine
Can someone put a new topic in the tech library on doing a passenger side axle seal. I have not problem tearing into it I would just like to know what I'm up against for time and if I have to drop the whole front end out.
you have to drop the diff unless you've done an E clip eliminator previously (If you've done that, just pull the passenger side tire and spindle, pull the shaft out of the diff and put the seal in). If you haven't pulled the diff before, I would leave yourself a day... It might be easier to just drop the drives side beam than do it with the axle in the truck. If you don't drop the beam (the way I did it when I had to reseal my pumpkin) I had to remove both front tires, spindles and axle shafts, the pinch bolt behind the drivers side radius arm, the front drive shaft and the 10 pig bolts
