Dana 30 SAS Guy need your help
Downey
Muncy, PA
Im trying to figure out the best way mount the radius arm style arms to the frame.
so question is how did you guys mount the arms?
what did you make your cross member/ arm mount out of?
pictures would be great
thank you
as seen in most threads, use 3/16" minimum...preferably 1/4" steel to make brackets to bolt to the frame at the stock tranny crossmember location....use 2" square tube (again 1/4" wall would be best) to make a new crossmember...
hope this helps ya:icon_thumby:
l8r, John
yea i have seen a couple different designs but was hoping for some pictures
transmission crossmember with RA mounts
if you were to do a 3-link or y-link radius arm... you could do the same.
of course, your arms will probably look more like this:
