Need help, got an 89 ranger that i swaped front axles with an 84 bronco2 with a dana 28. I am running 31x10.50 bfg a/t and a 2.3L. I recently changed front and rear ring and pinons from a 3.73 to 4.56. Went to 4.56 for highway engine speeds and performance with the larger tires. My question is after the front r&p swap oil sprays out ot the breather tube on top of the diff housing. I had no problems with it leaking with the 3.73's. What would be the reason for it and would it be harmful to plug the breather tube? It is also making a slight whining sound at cruising speeds when the hubs are locked in and tcase in 2wd.
Thanks
Thanks
