zapper2003
- Aug 12, 2007
Never done a ujoint in my life, and i've heard they can be a biatch. Regardless, this morning doing some light wheeling i heard a pop and low and behold one of the caps on the passengers side outer ujoint had grenaded, so now i've got an ugly ujoint that needs replacement. Are dana 28 and dana 35 ujoints the same? Which one will I need for this axle? Also, being as i've never done one, the way I understand is that I need to remove the nuts from both upper and lower balljoints and get teh entire spindle out of the way so that I can access the ujoint to change it. Is this correct? Do I HAVE to replace that rubber boot between the half-shaft and the stub shaft?
