D44HD TTB...stuffed under BII?
H311RzR
U.S. Military - Active
I picked up an 86 f-250 with the d44 ttb up front. I have read that these can be installed under the BII by shortening the drive shafts....I dont want to do that! I want to keep them full width.
Has anyone done this?
My thought was to lengthen the beams to match the mount points on the bronco? Any ideas?
I haven't done this but have read a fair amount. Lengthen the beams or move the pivots. Copykat [no longer on this forum, check dezertrangers, bII.org] has made wiy beam brackets w/1.5" lift that will accept both d-35 and d-44 beams. I bought some from him but haven't installed them yet. They are skookum. You can see if he is still doing these.
Good luck,
Richard
AWESOME... thank you! that is helping out a lot.
no problem...there's some info here too-http://www.therangerstation.com/forums/showthread.php?t=91231
but i didn't go into the detail nathan did.
