D35swap. Ok, how do i fix this one...
kolton
U.S. Military - Active
lewisville, Tx
Probably something for 4x4Junkie...
Ok, so me and my buddies ripped the old D28 out of my 87 Bii and bolted in a junkyard D35 out of a 91 xploder. Everything went well and it all seemed too good to be true actually. Untill we set it on the ground.
Drove it around the block so it would settle so we could align it. And when I pulled into the driveway my tires were almost literally facing like this "/--\" (front view)
Wheel berrings and balljoints are good, so I was pretty much just sumped.
Took it to an alignment shop and they said it was un-alignable. "The cams had already been turned all the way out" but I'm going to test that tomorrow because they didn't even look under the vehicle. They just saw it in the parking lot and said oh F that lol. Then I took it to 4wheel parts, they quoted me $260 for an alignment. So yeah pretty sure that's not happening.
Is there anything that I can/should do to aid this? This is my DD so I kinda need it back...
About the truck...
It has a superlift 4.5 or 4in lift kit and a 3in BL. On 33in tires. I used the same springs and everything that I was running on the D28.
Any help is much appreciated.
Thanks, kolton
This is the second time this truck has gotten a D35. The first on was lost in a wreck so I put the D28 back in. I never had this problem the first time.
Well, considering you had to do an entire beam swap, you're caster is probably, no, it is mess up. Along with some toe in issues, toe in will cause the tires to bend in like that and also give it some lift as the tires want to push the truck upwards. Assuming the picture is of toe and not camber.
If that's negative camber, could be toe out then which would cause tires to pull down the truck. Put the truck into reverse and see if the camber changes any. Sure sign of toe being out of alignment.
Does it pull to one side? Is there serious camber change throughout the steering from lock to lock?(bad caster)
In the end, install some adjustable bushings, and get it aligned. You CAN'T do it yourself. Those machines are accurate to something like .1% of a degree.
Toe is way off, the passenger side tierod end had been loosend by my friend... Didn't bother to tell me. So ill get that straight tomorrow.
The truck drives straight down the road, and in reverse the tires stand up a little, but not a whole lot. Driving forward the truck is pulled down towards the front.
/--\ is the view at the front of the truck, not from above. If that helps the ideas.
Oreilly's has the -4/+4 bushings, but from what it looks like, its way more than just 4degrees off
You have the steering linkage for the d35 on the truck right? Not the stock d28 linkage?
Yes, its the D35 steering linkage, with the 4in or 4.5in drop pitman arm.
Maybe the beams were cut and turned already if the camber is that far off. Does it look like they have been?
If the tires stand up when you reverse, your toe is off. The front of your tires are sticking 'out' too much, so when you drive forward, the suspension gets 'pushed' down. But......I doubt it would cause that much camber...
You have a Superlift 4.5" kit, which means you probably have two holes on your axle beam drop brackets. If so, which holes did you use, top or bottom holes??
that was my question.....if in the lower hole....move up to the upper hole....
l8r, John
Yes, definitely sounds like an alignment (toe-out) problem to me also. I'd try sticking a steel plate with a couple dowels under one of the front tires to relieve any tension between them and see where your camber really is (until you get the toe even close to correct, that's really about the only reliable way to do it. See near the bottom of this page).
Okay, so I fixed the toe out problems and the truck almost sits up as it should. Gonna go get the -4/+4 cams tomorrow and dail it all in. The lift only has one option for the beams to bolt up too. And no, the beams had never been cut and turned. (Damn I wish they had been though! Haha)
Ill update tomorrow and maby some pics if I can figure it out on my phone. Thanks
rember also, the d35 is a bit wider than the 28,so coil for coil, the coils are going to be shoter in static height so to say.
Got my adjustable bushings... How the hell do I dail this in? I'm reallÝ sorry for all the questions and I'm pretty sure I'm making this harder than it is.
How do I measure what the camber is at the moment? And what should I be adjusing it to?
Read the link three posts above yours.
