- Mar 24, 2008
- Age
- 47
- Howard City Michigan
- Automatic
Alright, I just put new gears in my front end and eliminated the C clip by welding the cap on the stub shaft and putting a spring inside of the slip shaft. My problem now is I get a noise from where the axle is pushed out against the spindle housing. The spring pressure is causing it to wear/rub and make noise. Should I just make it so it doesn't have any pressure on it during normal driving by shortening up the spring or getting a lighter spring? I am worried if I remove the spring preload so it doesn't push on the spindle, I might cause harm. Is this normal for this mod, and if it is, what did you do to fix it?
