Cylinder head replacement truck idling rough
Johnnyboiranger22
St Petersburg, FL
2.3 (4 Cylinder)
Did a new cylinder head and gasket, did timing marks and started her right up started fine but i'm notice this clanking noise and truck idles rough and engine light light came on and i don't know how to read the engine codes on these things. I will provide video to give an idea of what i'm talking about in case my sentences leave more you to be confused.
https://youtu.be/pC19kgSSMzw
1991 2.3l Lima engine
You may need to pull off the valve cover and have a look at the Rockers, noise could be rocker has slipped off so a valve is not opening
How long have you run it with the new head?
I recently changed the head on an 98 2.5L. Purchased brand new head complete.
It sounded just like that when first started!!! Let it idle for a half hour, started revving it a bit, noise got quieter. Revved it hard - noise went away completely. 1,500 miles later, still quiet, runs great.
Now, I am NOT recommending this method to fix it. In my case I would have been done with the vehicle entirely if I had blown it up. Just think the new valve train needed to "seat"?
Did you oil the head, cam and valves before starting?
If all you did was install a new cylinder head, then I would be removing the cam cover and inspecting. It's possible a cam follower got out of position, and can be pushed back in place.
Back when, the Lima came with 'hairsprings' or grasshopper springs to keep tension on the followers so they did not fall out of place. They quit that after a few seasons.
Other than that, it sounds like a collapsed lifter that is not pumping up. They can become jammed if fully compressed, and oil pressure may not be enough to expand them to normal size.
If that was the case, you have two choices: remove & replace a lifter that doesn't lift or remove, disassemble and un-jam the lifter/support, and replace.
If you run the engine with the cover off, you will rust-proof your engine compartment. A hurricane of oil will fling everywhere.
Start at the front and feel the followers for one or more that are floppy loose. They should not be that loose. Be careful as the machined edges will cut the snot out of your fingers if you are not. Remove the follower and pull the lifter support. Fiddle. Return, re-cover and start. It may clank or rap for a minute after startup, but should shut up within a few minutes at the outside.
One other alternative is to take it on the highway and run the rpms up so oil pressure is at a max. You do not want to do it sitting still as you'll cringe at the noise.
tom
