Cylinder 6 misfire 3.0L
cincyspqr
Alright guys, replaced the coil pack, spark plugs, wires, fuel filter.... what next? Idk why it's still misfiring... 85k on the engine. 140k on the truck. Any ideas or common problems?
Burnt Exhaust valve
Sent from my SM-J320V using Tapatalk
Ok thanks. I posted it in the wrong forum. Sorry guys. I'm new to this and idk how to delete it and repost it. Fml
The mods will move it to the 3.0. Create a detailed signature. We will need more info.
Done, thanks for the advice. It's happening only occasionally and only at idle for more than a minute or two. Runs a little rough.
1999 Ford Ranger XLT Reg Cab 4wd 3.0L flex- 140k on truck, engine replaced at 64k with LKQ rebuilt
Hmmm with rebuilt engine they should have solved the burnt valve issue. Does the Cel flash?(this is a misfire). What are the actual codes?
It does not flash. When the check engine light does come on which is infrequent, the code reads "misfire cylinder 6"
The only thing left is the fuel injector and compression or leak down Test. I would add some Techron to the gas tank just for giggles!
Done, praying it helps... [emoji23]
Ok I realized it idles rougher in drive than park. Just because it's set like that or?
