cylinder 3 and 6 misfire
ranger man'02
Forum Member
Jacksonville
FL - USA
Other
Vehicle
Drive
2WD
tested wires between coil pack and computer and i want to check the resistance of the coils in the coil pack what should the resistance to different pins be
The problem went away after probing wires and never came back.
Well, that may help narrow down where the problem is, depending on how much stuff you touched and moved.
I think when i disconnected the battery it reset the ecu the truck also sounds a bit like a diesel when smashing the accelerator and idles rough but it has done that since i got it.
Based on the year in your profile, I'm assuming you have a 4.0 SOHC. I would look at your timing chain tensioners. You don't want to be letting that noise issue go. If the chain guides break, you are looking at a pretty big repair. It might also be partially related to your idle issue.
I was told they fixed the timing tensioner problem in the late 90s but it almost sound like a knock when you rev it but its only right as you smash the pedal and it doesn't make the noise under load.
For the SOHC, it was later, like 2003. In any case, the tensioners wear out over time and need changed. Some say 70,000 miles and some say 100,000 miles.
When the tensioners wear out, they will allow the chain to slap on the guides and will eventually damage and break them, even on the later engines after they fixed the guide breaking issue.
that will cause it jump time right
They can do that as well, depending on how bad the guide damage gets and how long someone lets the problem go.
just checked with ford they claim the guides are maintnance free and haynes agrees
And the symtoms for bad chain tensioners do not line up with what I hear.
That means that when they go bad, you replace them.
Like light bulbs, head gaskets, and many other things.
yeah but sarg was saying they are a regular maintnance item
Event Coverage
TRS Merch
