the title pretty much describes it,
I have a 2000 4.0 OHV 4X4 with 152K on it, and it is throwing a CEL for Cyl1 misfire.
I replaced the plugs and wires, cleaned the MAF, MAF Plug, Coil pack, Coil pack plug, and it still hasn't gone away.
2 other things I've noticed, that I am unsure if they are related or not,
1) The truck smells a bit 'sulfury' but I just replaced brake pads and bearing and haven't gotten around to replacing the warped rotor yet, but the smell seems to come from the opposite side of the truck *pass side is the smell, driver side front is the new pads*
2) Also, the Both cats make ALOT of crackling/pinging sounds after I turn the truck off (pass side of truck also), I know it will ping a bit, but its sizzling inside of both of them, which seems unusual.
Suggestions? Can a single cyl be impacted with a failing coil? Can clogged cats cause a miss JUST below 2000RPM?
