- Aug 9, 2007
- Age
- 41
- auburn/minot maine
- Manual
whats the difference between a cvt and an Ecvt transmission?? Thanks for the info
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
So is a CVT something like a 12 speed bike chain? but not as clunky?
CVT is a really cool concept that never -quite- pans out for higher output applications. The Fiesta and Justy go back to the late 80's, but that was behind anemic engines. And Audi jumped in with performance applications quite a while ago using a chain based system. It just doesn't hold up all that well so far outside of high efficiency/low output use.Nope a 12 speed bike still has gears. There are no gears in a CVT just cones. As the cones move, the belt slides up one and down the other varying the ratio.
Simple image of the inside of a CVT.
Simple image of the inside of a ECVT
I don't see no cones, Kenny?
Snapper has used this system on their lawnmowers since the 60's.CVT is a really cool concept that never -quite- pans out for higher output applications. The Fiesta and Justy go back to the late 80's, but that was behind anemic engines. And Audi jumped in with performance applications quite a while ago using a chain based system. It just doesn't hold up all that well so far outside of high efficiency/low output use.
A few years ago I got to see a whole different kind of CVT in a car at the Fountainhead museum. The 1907 Cartercar had a handle that the driver used to slide the friction surface across a flywheel with a pedal engaged to separate them. Release the pedal with the friction surface on one side of the flywheel and you're moving in reverse. Slide it across to the other side and you can progressively access higher speeds depending entirely on where you position the friction wheel.
