ForOffRoadDriving
ok, i knowthis isnt the right forum for this, but i need an answer to this fast. so i work at a parts store and was recently volunteered to do a front end overhaul on a customers ranger. not too bad since i like to work on rangers, but im not experienced with 1998 & + rangers and this is a 2000. anyways, i have removed the vaccum hubs, the tie rods, the upper control arms, the steering knuckles, and the drivers side cv shaft. i have got the passenger side almost out but it hits the shock on on that side. if i remove the shock, i suspect the torsion bar will roll the lower control arm down and i wont be able to get the shock reconnected without removing the torsion bar adjuster bolt and then reconnecting the shock. im also having trouble with pressing out the lower ball joints, but i think some heat will free them up and that should be that. any advice would be great. i have to go back and finish this job on monday and if it wasnt for this driveshaft hang up i would have probably finished this tonight. ahhhhhh F***ING FORD! no, i dont really mean it, but i know weve all said that. any help would be great guys, thanks in advance for your vast knowledge of all things ford.
