CV joint b2b drive shaft replacement
nutpantz
Is there any drop in replacement for the CV joint drive shaft in my 90 b2 m5od 4x4 factory unit?
If not
What's the best drive shaft to get to resize?
(I plan to go to a explorer 8.8 disk Brake rear end come spring if not before is that affects my choice)
Best thing I know of is the front shaft out of a 91 to 95 (last year I am sure of) and get it resized. You need to put different flanges on the back of the T-case and the pinion of the rear axle to accept the bare U-joint though.
