Defective
- Sep 25, 2007
- Age
- 48
What could cause the truck to intermittantly cut out going down the road?
This morning about 25 miles into my commute, I go to pass somebody, and when I hit my turn signal the truck acted like the electrical system was completely deactivated for a split second. The radio channels reset and the ABS light came on and stayed on. The truck drove normal again for a while then did it again right when I hit the turn signal. I played around with the turn signal lever but couldn't duplicate the problem. A few more miles down the road it cuts out a couple times in succession, without the turn signal, and acts like it's going to die so I pull over and look things over. Everything seemed normal. Tried to pull codes and got none. Shutting the truck off reset the ABS light.
Back on the road, it continued to do this here and there for rest of the drive and even completely died twice when I got to town traffic. It also cut out when I hit the window switch a couple of times. It wont do it every time, it's like it takes minute between before it will do it again.
Everything else is normal, except for the secend time now, my clutch felt like it was toast for the first 20 or 25 miles of the trip. Feels solid again though.
