Custom Intake Question
chrmaka
Okay to you guys that built a custom intake. I'm looking at building a better flowing intake with an open element filter. I'm stumped right now for what to do with the MAF. What did you guys use for a MAF housing that worked on your truck. My truck is a 2006 sport.
Since the 04 and newer 3.0's had the MAF integrated into the airbox lid, the only thing you can do is cut the MAF off and make a mount for it out of sheet metal or something. You may be able to use a MAF from an older 3.0 that wasn't molded to the airbox, but I'm not sure how different the wiring is.
Stmitch, I have the ability to pull the whole sensor to be able to change the housing. Would the older 3.0 housing be compatible with my newer MAF?
Sent from my VS890 4G using Tapatalk
I have no idea. I'm not sure if the diameter of the housings is any different (the 04+ MAF looks smaller in pictures to me) and I don't know how the newer MAFs fit into the housings. You'd be the first person I've seen to attempt it.
Okay, I have a buddy with an 01 with the 3.0, I'll get with him and play around with the housings a bit, I'll report my findings. Worse case scenario is the parts are incompatible or require modifications
