Cruise control won't engage
msubully82
1994 Ranger with 4.0L, manual trans. - cruise won't engage. The light doesn't even come on. Is the most likely failure the switch in the steering wheel? If so, is cleaning an option or just replace? I haven't even checked to see if you can still buy the switch.
I would check the fuse first and jump to the switch or module under the hood.
Yes, there are a couple of fuses to check.
Does the horn work?
That's one fuse, it powers the ON/OFF cruise button
Go here: http://www.therangerstation.com/tech_library/EDiagrams/index.htm
Look at the end of Electronic Engine controls
Cruise 1 and 2
You need both
Fuse numbers can change yearly so they are not specific in the drawings, could match your year but may not, but the wiring itself will be correct
