fastpakr
Forum Staff Member
TRS Event Staff
- Aug 6, 2007
- Roanoke, VA
- Automatic
- Tire Size
- 285/75-16
I'm trying to sort out the problem with the cruise on my '94 Explorer. I've verified that all the secondary components are ok like brake on/off, clutch switch, and dump valve. All vacuum lines are good.
Per the manual I'm reading, I should be getting a constant ~8 volts on the control input wire at the cruise amp. I'm actually getting zero. It goes to 12v when the On button is pressed, but all other buttons are zero. Resistance checks for each switch, however, match the specs in the book. Does anybody know what would be causing this to happen? There's a reference in the manual to checking for a shorted clock spring if this happens on an Aerostar, but no suggestions to the appropriate solution on a Ranger/Explorer.
I tested for continuity between each of the rings at the back of the steering wheel, and none of them are shorted to each other. I do get continuity between the inner and outer terminals coming from the steering column to the wheel, however. Not sure if this is normal or not.
Suggestions from those with experience would be helpful.
