cruisinflatout
Crazy Shudder during Initial Acceleration (< 30 KPH)
I just bought an 89 Ranger 4x4. The guy I bought it from recently replaced the clutch and had the flywheel resurfaced but failed to replace the clutch slave while he was in there! The truck wouldn't shift into gear and the clutch tube (hydralic line) was cracked too so he dumped it.
Needless to say, I saved some cash by buying it in this condition.
I dropped the transmission this past weekend, replaced the slave and line and put it all back together. Changed fluids in the tranny (80w90) , transfer case (Mercon ATF) and rear end (80w90).
Now it shifts awesome but I have a pretty big shimmy anywhere form 0-30 KPH (0-20 MPH) and a slight vibration at all speeds.
I tried reversing the main driveshaft 180 degrees to no avail.
I read that a shimmy at first acceleration could be caused by the pressure plate not being torqued down properly. However, if I let the clutch out completely without acceleration, the shimmy is still there once I do hit the gas. The vibration also comes back when I decelerrate slower than 30 and it doesn't matter if I have the clutch engaged or not at the time.
I have also noticed some fluid splatter around the rear diff (looks old). Could this be a rear diff problem?
Any ideas on what the cause could be? Wrong fluids? Need Friction modifier? Need lube on driveshaft splines? Something mounted wrong (although I don't see how)?
Thank you for your time;
Kevin
Regina, SK, Canada
1989 Ford Ranger 4x4
3.9L 5 Speed Manual.
Kevin
Regina, SK, Canada
